"Bug" in the PowerThdVersusFrequency Automated test?
I was trying to measure a subwoofer amp over the frequency range 20hz-200hz using the PowerThdVersusFrequency Automated test, and ran into a problem in that the routine sets the power to the desired level at 1khz, instead of at a frequency in the middle of the desired range, say 120hz in this instance. Since the subwoofer amp filters frequencies above ~200hz, the test aborts as it can’t reach the desired power level. The automated test does not appear to use any of the settings from the current THD test panel,where the generator was set to 125hz with an input loss of 12dB. Maybe I am missing something? Thanks
That’s an interesting use case for sure, Scott, and I can’t think of a solution to it, whilst staying in that particular automated test parameters.
I figure you are dummy loading the subwoofer amp and testing the entire amp+filter unit as one black box anyway, so the simplest way would be to do some spot frequency power vs THD tests and plot (manually) the trend?
I reckon within the 20Hz to 200Hz, the subwoofer system will have a pretty uniform THD except maybe around 60Hz (for you in the US), if a conventional power transformer/rectifier/cap supply, even if it’s an old class-D design. For an SMPS powered sub, I reckon it would be pretty flat all in all.
Thanks for the reply, John. Yes, the amp is being loaded with a four ohm load and powered by a smps amp it looks like. Since I am going through the line input “preamp section as well”, it is lowpass filtered and not very flat at all, so just a thd/snr few plots around 45hz are needed. Probably an easily implemented fix…
Hi @Var, yes, testing subs isn’t something the test really contemplates. Probably it would make sense to let the user specify the probe frequency.
@matt That would be great- default to 1khz with the ability to change it…
