FFT Peak L and R data
After selecting peak data points on the L channel, the data in the top right corner matches the Left DISPLAY actual. Switching to the Right DISPLAY keeps the Left channel data in the top right. Is there a way to see the data for the Right channel?
Hi @DPBrew, not in the 1.x releases of the software. I think before December, the first 2.0 release will be out and it addresses this limitation. You can put the right channel in its own window and add the markers there:
Or you can put the left and right plots in the same window and add the markers there
There’s also a summary that will show harmonics automatically
I would like to see at least up to H9. Max H6 is quite a limitation. Perhaps make it adjustable for a certain range (H4….H10)?
That’s looking really good, Matt. Very nice layout, clear and uncluttered.
I can’t imagine the hours of work going into software development.
