I’ve been trying to measure a transformer-balanced unit. The output transformer (in combination with a DC blocking cap) creates a peak at the very low frequencies.
However, it is rather difficult to measure the exact frequency and amplitude since it varies depending on the FFT size.
Please see this plots below. Which FFT size should I trust? FWIW, the applied signal is +4dbu.
I thought that the higher the FFt size, the smoother the curve would be (this is the case also when using REW) but with the QA403 it doesn’t seem to be the case.
In fact, I’m not even sure if this LF peak is real or some digital measurement artifact.
