Hello Legion of QuantAsylum’ers,
I started using a QA401 for the first time to test a device… mainly just Frequency Response plugin’s ( regular and Chirp).
I keep getting a huge HF rise starting about 1k ( attached screenshot)… like crazy rise…
I thought something was wrong with the DUT…
But, just to be sure, I disconnected and did loopback from OUT to INPUT of QA401, and got perfectly flat response…mmmmmmm…guess my DUT is damaged.
But, continued testing…
- an electronically balanced AD/DA - this gave completely flat response just like the loopback…
mmmmmm… DEFINITELY! my DUT is bad!
But, I tested one more device… one I know is good- but is similar somewhat in design.
- Transformer Balanced line amp - this unit gave almost the exact same Frequency response results
… same huge rise in HF starting at 1k… ODD!!.. Both devices broken?.. probably not…
So, I started trying different connections to DU… added load resistors( even though I know both devices are properly terminated… but why not try it,… same RF rise when running Frequency Response Plugins…
Went on to try different cabling… shorting ( -) to ground on cables connecting I/O of DUT… still same
test results.
So, humbly, I come before the council of Quant and beg for enlightenment… why do transformer balanced DUT behave this way?.. what am I missing?.. I have datasheets for the devices and know that they are essentially flat from 20 to 20k …
Very curioius to me that both devices would have this same result.
Very much appreciate your thoughts and help on this.
Thank you,
Bingo!
