I found a couple of older, unresolved topics on the matter, but haven’t found a good answer. Essentially, I’m trying to measure a high end DAC - specifically the differential output of an ES9039SPRO @ 4Vrms. According to the datasheet
When I use the QA403 alone, I get a reading of around -115dB, which I think is limited by the QA403 itself. I’ve finally managed to get all the adapters and what not to add a notch into the loop - this particular notch has a -30dB gain at 1KHz, immediately followed by 20dB of gain.
I’m following this guide, for reference.
Firstly, I sweep the notch. Specifically, I am using a sweep at -20dBFS (to account for the notch’s built in 20dB gain), and I have set the differential output of the DUT to 4Vrms. The result is this:
I then export the notch and do another sweep with it enabled as a user weighting to prove it looks as it should do:
I’m not entirely sure whether my next steps are correct. With no stimulus and no weight, the noise is just flat across the frequency spectrum. With no stimulus and the user weighting applied, I can see the positive compensation of the weighting at 1KHz:
Now I play a 1KHz tone, with the user weighting applied, and at -20dBFS. The reported THD+N is -104dB:
Now, how do I interpret this? Do I add 20dB to account for the built in gain of the notch?
Alternatively, I play a 0dBFS 1KHz sine wave and now it’s reporting a THD+N of ~-124dB.
This can’t be right - that’s exceeding the spec of given in the datasheet. To take it to the extreme, if I repeat the steps above but add 60dB instead of 20dB of gain to the notch, I start getting crazy numbers like a THD+N of -127dB.
So could anyone advise on where I might be double-counting, or something?
