I hooked up the QA402 and did some testing.
First thing it did was a firmware update. It then needed a power cycle to come back on line.
I found that the software is pretty intuitive, although I did manage to bomb it a few times.
I was wondering about the THD % tile, can you increase the decimal places to say 5?
Looking forward to running some of the plug-ins for power and distortion.
Hi @Botte, glad the unit arrived. There should be a SW release today or tomorrow that pulls in the frequency response measurements along with other bug fixes. Noted on the tiles with % and precision. Thereās a crash issue with zooming in the graph and markers that will be merged in early next week. Is there a specific plug-in from the QA401 youād put to use? If so, I can get it into the release for next week. Thanks for your patience.
I have been doing some more testing.
I see that the context menus donāt always popup on right click, they do if you hold the left button down.
Iām also wondering about some increased precision on the output level. With one dB steps I seem to be under or over my one watt level Iām shooting for.
QA402 can work like a DAC ? Can we listen music with it ?
Not currently
but the PDF for the QA402 says QA401 at the top:
Fixed, thanks!
Should be fixed in next release
I see that I can change the level with the context menu for the generator.
There is a bug that will be fixed for next release: In the Gen context menu you can set the sensitivity ty of the amp up/down button. That was being ignored (always 1). But in the next release it is respected. Also, note if you set the sensitivity to 1 dB, if you control+click the amplitude button then it will move 10X more (10 dB per click). And if you alt+click the amplitude button, it will move 0.1X more (0.1 dB/step)
There is also a bug where input left/right are sometimes swapped that is being worked on. The fix might not be in todayās release, but hopefully this week.
Front-panel I2S has been confirmed on the previously mentioned isolator board at 32 bits at 48K. But thereās a issue where the front-panel output DAC data hangs that is being studied. So the I2S button is disabled for now. The control cluster has the re-organized in the next release too to hopefully better convey intent
Thereās also some more visual changes to better convey whether you are in ātonesā mode (fixed sines) or chirp mode (in freq response mode).
The FR setting gets its own amplitude control button too as previously you had to go into the context menu to change.
I have a question about the attenuators, when I turn it off I see a much lower 60 and 120 Hz power spikes. They move up and down with the noise floor with the atten. Does this make this a test setup noise issue?
There are two things to keep in mind here. First, is that the system will generally deliver a constant dynamic range. That is, when the max input moves from 0 dBV to 6 dBV, the measured noise (RMS, 20 to 20 kHz) will increase by 6 dB. So, your noise is 6 dB higher, but your max input is also 6 dB higher.
The second thing at work here is the associated resistances. At 0 dBV max input with inputs shorted, the equivalent input resistance is about 500 ohms. At 18 dBV max input, the eq input resistance is about 6k. That 6k has considerably higher thermal noise, and the bias current of the opamp (OPA1656) is also suffering a bit there too BUT, as the OPA1656 is CMOS, the bias current noise is very small relative to the thermal noise.
In short, just think of the analyzer as delivering a constant dynamic range and that will let you estimate the noise floor at every input setting. If the RMS noise is -115 dBV (0 dB input), then at 42 dBV input, we might expect the noise to be at -73 dBV
Feel free to start another thread on QA402 questions and issues as this thread is a bit long and Discourse isnāt great on super long threads (but itās excellent on short threads).
