Hi
Try to use 40x Plot
Walter
Hi
Try to use 40x Plot
Walter
Hi @walge, does the right mouse button do anything? Do you have another computer you could try this on?
Ho
The mouse run fine with others sw
Walter
Hi Matt
with Plot I can work without any problems
In the frame, each time I do Zoom in a Y scale change.
It is normal?
Do you think will be possible to use the wheel of the mouse as Plot does?
For zoon in and out, will be more easy, I think
Walter
Hi @walge, the wheel won’t work in the current software for zooming, but it does in the 2.0 software for later this year.
Hi
I have done some test of Dac with impulse in the lab of Audioreview here in Italy
We have compared the signal sent to dac and taken on analog ouput; in parallel with 403 and a scope.
This to compare the standard test done for review on magazine with the results from 403
In attach the impulse done with sampling of 48kHz, no oversampling
The 403 set to 192k
It is a very good results comparable with the scope.
This one with oversampling
In this case is comparable with scope, the pre and post ringing are the same, as expected.
With the impulse at 192kHz of sampling the differences are more evident
So the test with 493 are very good for impulse of 48 kHz of sampling
Walter
