THD measurement lower than 127 dB
Maybe it is ghost chasing, but I tried to figure out the best “floor” readings I can get out from my QA403.
Connecting a QA403 to a tower PC running Debian Linux 13, Trixie, I was also able to run the QA40x software.
while connected via a straight USB-B to A cable, a loopback to itself in single-ended on left channel allow THD measurement to cross the -126 dB level and SNR is very close to 110 dB. All 3 other inputs have shorting plugs.
When using an external 5V wall adaptor to drive the QA403 via a modified USB cable, I am able to get a THD measurement under -127.5 dB and SNR almost hit 111 dB.
A direct USB cable show the voltage displayed by the QA403 to be 4.75VDC or a bit above.
The use of an external power supply and a modified USB cable show 4.97 VDC or a bit above.
The QA403 I have is able to go so low only if certain conditions are met.
The GEN1 output must be set to -0,23 dB / 1kHz.
Right channel is muted
GEN2 output is set to -150 dB / 23 kHz. (so as not to interfere)
FFT using flat-top window and set to 1024K.
Sample rate 48K
Full Scale Input is +6 dB
Average is 100
When 100 readings are completed, I read -127.51 THD or lower and 110.94 dB SNR or higher.
Changing the orientation of the unit, I was able to get the 60 Hz at lower than -142.7 dB.
The right channel does not have numbers as good. (2 or 3 dB difference on both SNR and THD)
Having the left channel set to -165 dB / 23 kHz and all 4 inputs shorted, the highest peak I get is for 60 Hz and it is blow - 155 dB. The rest of the 20-20,000 bandwidth is below -160 dB.
If you want to get better, use a low distortion (lower than the QA403’s DAC) 1kHz source. The QA403 DAC is the limiting factor, not the ADC.
I had read about QA403 DAC being less capable than the ADC.
However, finding a cleaner 1 kHz source seems harder than I thought, especially when cost is a limitation. Exploring the internet has brought some possibilities to the surface. Some seems too good to be true. Others are not available anymore.
I will keep digging.
A pearl may cross my path.
Yves, this is one of the lowest distortion Oscillators that I have come across. Maybe there are other options that I have not learned about.
Thank you Mark.
You are right.
I saw this one through my research and found nothing else getting close to these specs.
I have sent an email to answer questions.
Do they ship to Canada? What would be the total cost for a unit?
I would still have to build or get a 35V power supply and proper case, but that is not a problem.
65 Euros international shipping. It’s on the page.
Its hard to reduce several harmonics simultaneously (you can cascade twin-T passive notch filters to do this but you lose a lot of amplitude and risk high noise levels). A simple passive low-pass won’t buy much harmonic attenuation for the low harmonics.
Perhaps you can measure harmonics separately using a different filter on the DAC output for each measurement (twin-T’s for 2nd and 3rd, low pass for the rest?). Of course you’ve got to be sure distortion level of the passives used in these filters.
Characterizing the DAC can be done by knocking out the fundamental with a notch - standard approach really, then you can measure the residual for the DAC (it will depend on amplitude and loading no doubt, so watch out for these). Given the known residual of the DAC you can in theory subtract it from other residual measurements you take.
@MarkT And here you show me that there is plenty that I really do not understand. I know the filter shapes that you are talking about. And the general flow of the filtering. How to do this in DSP is not something that I have tried to do.
It cannot be done in DSP, you have to manipulate the analog signal to improve the headroom between harmonic(s) you are interested in and the overall signal, using ultra-low distortion components.
This is commonly done when measuring an external DUT by using a notch on the fundamental (getting an extra 40dB dynamic range is routinely possible) - here we want to do the opposite, suppress the harmonics and not the fundamental, which is intrinsically harder in practice.
I acquired a S.M.S.L DO100 pro DAC.
Using AUDACITY software, I created a sample 1 KHz signal and fed it to the QA403 via the DO100 DAC.
The net result is that THD level went down below -130 dB. Almost a 4 dB gain.
However, SNR went from 111 dB down to 101 dB.
Looks like I have been able to get my ghost, after all.
Thanks for comments.
Hi All,
after finally upgrading from a QA400 to a QA403, I ran some tests and comparaisons using QA403 + Cosmos APU Notch + Victor generator.
Without further due, here are the VERY impressive results, to me, this setup gives:
I Think pictures speak louder than words !
How to get there , I followed Mat notch procedure where he details how to run a frequency test first then with file export I got the notch weighing file automatically. Thank you Mat for such a great feature ! Before I did that I had measured the Victor frequency which in the picture is 997,489Hz and not 1Khz… you have to let your vitcor oscillator warm up and measure i’ts frequency then…
I did this tests three times, three days in a row , to make sure I was abble to “REPEAT” my measurements !
I did, sometimes if you don’t wait long enough you’ll get a THD of -141,77 :rofl: :joy: !
When I started the tests I ran the notch without the +6db and got this :slight_smile:
Which was my first trial , than I used the +6db and got consistently still better results all the time…
I took care of comparing how much “error” you would get without no weighing / no displayed correction , like when you are running it with a ten year old QA400 and the results are :slight_smile:
THD = -141,84 db instead of -141,22 db… I saw on average -0,7db or less imprecision still very impressive in my book … SNR = -121,25 instead of -120,97…etc…
So this lead to my tests of the OLD QA 400 and the results are :slight_smile:
This the best THD measurement I could get lowering the output of the Victor oscillator to be just at -0,1 db input at the QA 400 , Quick results when you take off -30db , THD = -130 db for a ten yeas old unit ! best SNR / THD+N I could get :slight_smile:
Quick SNR = -120 db , THD+N =- 119 db , THD = -128,9 db
My Setup:
I power the victor oscillator with a lab bench power supply old style that is not noisy, I run the COSMOS APU on a battery pack. For the QA 400, I use an OPTOISOLATOR on the QA 400… to mimic newer units and be abble to do floating (quasi) symetrique measures with the older unit :slight_smile: plus my -20 db / -40 db homemade QA probe :wink: and I lower the Victor oscillator output with the pot…
In my book these are remarkable numbers for both units ! an inexpensive way to be like the big boys!
Bravo Mat !
PS: I devised a simple way to treat QA 400 pluging csv output files automatically with Claude AI, I 'll give the shareable link and my prompt in a separate post. I will also detail how to get with the old QA 400 about -4,5 db better THD common measurements using a -20 db probe, the QA 400 doesn’t like to high an input level as seen in my two above captures, you slightly improve your measures as you do with the newer QAx attenuators…:slight_smile: I am also doing a small video about my new QA403 plus APU and Victor and QA400 results !
