I’m not a fan of the BNC cables. I mainly use the QA403 for commercial amp/preamp/… testing and much of this stuff is unbalanced while some is balanced. This means I use almost exclusively RCA and XLR jack/cables and I never use BNC cables.
I tried making custom dual BNC->XLR and dual BNC->RCA cables and frankly just failed at it. All the BNC connectors I found were designed to use coax and connecting other cables was problematic at best.
Anyone, rather than constantly suffer icky cables I just built a BNC->XLR converter that stays on my QA403 constantly. A few photos->
I started by 3d printing the front/back panels and supports and did a sanity check - which worked well. Then I milled front and back panels from 2mm aluminum. Note I rear-mounted the XLR adapters to make it easy to replace the front panel for an additional output connector (RCA?).
If anyone wants the models I’m happy to post the Fusion360 design/manufacture files or the .STL 3d printing models.
You could also use three pieces of plastic light pipe drilled through the adaptor plates and up against the LEDs on the QA403 to duplicate the indicators on your adaptor.
That’s a cool solution. If it’s going to connect to the enclosure anyway, it could be simplified by losing the center plate and using line BnCs. I would have probably chosen the spring-latch XLR-F instead of the button latch, but that’s a personal choice.
FWIW, Matt, I bought my QA already, but if I had had an equal or nearly equal price option to buy with XLRs, I would have gone that direction.
Unfortunately Amazon isn’t shipping these bnc adapters to Germany… There are a lot of female adapters out there, but I found only one male adapter for soldering, but it lacks the ground latch.
The amphenol part looks fine. You really don’t want it to be able to rotate - which that works for.
Bolt lengths - unlike everything else, I did those by eye and bought a selection of M2.5 hex standoffs. The length is critical if you have a plate for the Bncs (like I do). That measures as about 28mm but I used two standoffs and a nut as you can see in the photo.
The length between the BNCs and XLRs isn’t nearly as critical since the solder wires have some slack in distance. I used 30mm which gave a tiny bit of free space between the connectors. 32mm might be more comfortable.
I know it’s been a while, but recently I’ve had to remove my XLR adapter to use BNC cables and while reassembling it thought I’d compare the two configurations. So, randomly here’s a comparison of two reasonable BNC coax cables (for balanced i/o) vs an inexpensive XLR balanced cable doing a loopback test (QA403 output→QA403 input) on the left channel of my QA403. The red is BNC, the white is XLR. The right channel also had a loopback signal for both.
There’s a tiny amount of 60Hz pickup in the XLR cables but otherwise they’re pretty close.
I made a 3D printed support for two male and two female XLR panel jacks, many standard ones fit with mounting screws on a 19X24mm rectangle. I cut BNC cables in half and wired them to the jacks. I used 4-40 hardware with hexagonal holes in back to hold the nuts. The analyzer rubber feet fit in the base solidly. Performance is about the same as unbalanced, using a short snake cable as jumpers. DMX terminators can be used for unused inputs.
I’m curious about your coax grounds. I always wonder what to do with them or the equivalent in my XLR front.
It looks like you tie each pair to the XLR ground pin and at least on the outputs not to the XLR chassis ground. I’m not saying it’s bad, quite the opposite I have no idea, but I’m wondering if you
tied them together for some analytical reason or because you felt it was the right thing to do
what did you do with the XLR chassis grounds (I can’t really tell from the photo)
Well, what to connect XLR pin one to is always a question. If it was a true differential input / output, pin 1 should probably go to the chassis to keep shield ground currents from going into the box, but that is not what I guessed from the design. Since the BNC outer conductor is isolated from the chassis, I guessed that is the reference for the circuitry, and connected those to pin one on the XLR. The chassis grounds are not connected to anything, but probably should go to the chassis. Without knowing the actual circuit in the analyzer, I did not really know what to do, tried it one way and it worked. It it had not worked well, I would have tried something else. In a strong RF field, you do generally want shield ground currents to go to the chassis, not into the box to corrupt the PWB ground, but this is not going to be used in such conditions.
