BNC to XLR Adapter
Hello made me an nice XLR to BNC Adapter you could use at Input or Output with realy short wire in between :wink:
Used this Differential to Single endet Adapter and removed the Transformer and Chinch Conector.
Did an Drawing because its not much Room for Errors.
Soldering: (Reworked, now β€œ+” Wire and β€œ-” Wire have neare the same Lenght)
Seems to be important :wink: Same Measurment bwefore and after :crazy_face: I am not an Expert!
Ready to rumble:
You can use not isulated BNC Conector, they much cheeper, but didn’t have one right now ;).
But the Isolated BNC are realy nice to Solder to the GND not sure if the non Isolated realy better here.
Robert
Very interesting and creative solution, Robert. I like the adaptation of existing products.
Might I respectfully suggest that the difference in internal wire length is unimportant. Remember, our balanced analog interfaces, especially at low level like microphones, really want to be a twisted pair to reduce noise pickup. I’d recommend that the BNC cables between this adapter and the QA box be twisted around each other, which will greatly reduce the magnetic susceptibility in them. Try running your comparison again, except with the BNC cables twisted around each other vs. separated into a large area open loop. That may have been the source of your measurement differences.
Search my posts here to see my solution using Neutrik Bi-sexual XLR connectors and an in-line Y splice.
Dale
did youre Advice
And Measured it again with twisted BNC Cabel but didn’t see much different @ the lower End.
Twisted not Twisted
Hard to see Differences but Twisted at least a bit better THD+N and THD.
Robert
This Connectors would help to :wink:
Need to test it, order Placed:
https://www.amazon.de/dp/B0G25JPXB2?psc=1&smid=A3KRYOEMM87WKZ&ref_=chk_typ_imgToDp
Not sure but if you use BNC 50 Omm on the XLR Box you need to use 50 Ohm BNC to BNC Connector as well.
75Ohm and 50Ohm didn’t fit well mechanicly the Pin has slightly different with i guess!
On this short distance it didn’t makes (electrically) any difference thou.
BNC Connector fit’s very well:
