Where can we read more abut possible command line options. I know there are some, but the explanations about their usability is limited. Is there a list with all options and good explanations somewhere? I’m using a QA403…
Hi @Gerrittube, you can do a qa40x -h from a command line and you’ll see the following:
Note that outside of -L and -C these are not generally needed, and/or are experimental, and/or you might be asked to try by support in certain cases.
OK, that’s a good help. Where are the log files stored and with what name(s)?
Exceptions are stored here:
C:\Users\USERNAME\Documents\QuantAsylum\QA40x\ExceptionLog
And logs are stored here:
C:\Users\USERNAME\Documents\QuantAsylum\QA40x\Log
Make sure you have logging turned on to have logs created.
