Confusion about cabling
I’m confused about how to cable the QA403 to the devices I’d like to test. I’ve read the manual, wiki, and searched through the forum but I didn’t find the answers I was seeking (or I didn’t see how to apply the info to my situation). I then tried AI (Google Gemini) and my confusion got worse.
I’m interested in using the QA403 to test bridged class D 2-channel audio amplifiers. This diagram shows the setup I envision:
Can I cable an output, say R+, on the QA403 directly to one of the inputs on the amp (say the Right channel) via a BNC cable from the QA403 using a BNC-to-RCA adapter at the amp? Or must I make a special cable that would connect both the R+ and R- outputs to a single RCA connector (where R- would take the place of the RCA ground)?
The most convenient place to take measurements is at the dummy load’s + and - terminals. I couldn’t see how to do that using just a single input on the QA403 (say R+). Instead, I thought I’d need to create a special cable to connect the dummy load + to the R+ input and the dummy load - to the R- input. This diagram shows what I think the special cable should look like:
I’ll change the connectors at the end of the cable from banana plugs to spade connectors.
Is a special cable (such as I’ve described) required? Or is there another way that the QA400 should be wired to the terminals of the dummy load?
I can’t help thinking that I’ve misunderstood how the QA403 needs to be cabled. Since the shields of all of the QA403’s BNC connectors are tied together, I couldn’t see how I could use just one cable in a single-ended fashion (where is the signal return path?).
The shields are tied together, like on any piece of equipment. Your options are use only the +, where the shield acts as the -, just like with most consumer gear (single ended), or do what you described and build special cables. But I would build the cable using a single shielded pair, and at the QA403 end split the shield to each of the BNC shields, and at the the other end, the speaker connectors on the 2 twisted wires, with the shield just floating. I ended up making dual BNC->XLR adapters to make that easy.
Thank you.
Once I realized that the output channels of the QA403 always present the same signal on both channels, and that the outer shell of all 8 BNC connectors share a common ground, I was able to piece together the cabling I’d need.
I gauged that, since the BTL amp I’m using for testing has only an RCA (SE) input I would have to use a SE output from the QA403.
I’d only use a differential cable from the QA403 output if the DUT (Device Under Test) had differential inputs.
Since the amp that I’m testing has a BTL output (where neither speaker terminal is connected to ground, and both actively carry voltage), I knew that I couldn’t use a SE cable. I fabricated a differential cable to use when measuring the amp.
I figure that there’s no harm in using a differential input to the QA403 even when the DUT has SE outputs. I expect that I’ll use the differential cable (and differential inputs on the QA403) for just about everything.
I’ve spent a few hours playing with the QA403, going through the “Getting Started” material and some of the exercises in Bob Cordell’s tutorial.
