Hi @hasi, thanks for sending the SN. I pulled the test data on your unit and nothing is unexpected and of course everything passed before going out the door.
But I also wrote a small app to look at the statistical differences across all the QA403 units that have been made thus far. On these larger sample sizes, there is roughly a 5 dB difference between THD mean on left and right channel, with the left channel being better (note: The QA403 swaps the left and right channel for layout reasons). The standard deviation on the THD measurement shows the right channel has about 20% higher standard deviation. So, these numbers all come together and at the end of the day, you can probably find particular DACs and ADCs with wide ranges of performance between left and right channels if you look at enough units. It also suggests that grading a future audio analyzer might make sense, and charge a premium for really good performance (aka tightly matched).
When a QA403 gets tested, the focus is primarily testing at the hardware relay boundaries, because we want to make sure the difference in output (level, noise, THD, etc) at -12 and -13 dBV is very similar. This is because as you transition from -13 to -12 dBV, you’ll hear a relay click and we’re trying to detect a missing part, wrong part or a missed solder joint. Additionally testing is done at very high output levels (+17 and +18 dBV) because this helps shake out problems in the supplies (for example, a backwards diode in the isolated DCDC converter allows it kind of work, but the voltage is diminished and the LDO that follows the DCDC is thus in dropout and not doing it’s job. So, you test at +18 dBV and make sure the THD is as expected to detect this. Outside of the relay input and output boundaries, we rely on the ADC manufacturers test limit. In other words, we don’t check performance at -30 dBV, -40 dBV, etc.
I’ve put two plots next to each other. The plot on the left is from the QA403 product brochure, and the plot on the right is your data. Note in the product brochure there is an outlier trace on the left channel at -30 dBV. Yours looks to have an outlier trace at -30 dBV on the right channel.
In the product brochure, note how the performance tightens as you get to 6 kHz, while both my plot and your plot showed a spread at 6 kHz that was closer to the spread shown at 1 kHz.
Finally, note that your unit is showing THD at -123 in the left channel at lower input levels and higher frequencies. My unit showed even better performance than that at 6 kHz.
In summary, your unit is functioning withing in the limits of the ADC manufacturer’s limits and our limits. Your left channel performance is quite good–better than what was shown in the product brochure. We’ll look into potentially sorting units in the future and charging a baseline price for nominal performance and a premium for units that are more tightly matched.
