I am currently using application V1.202 on my QA403.
I have small issue when I launch the QA40x application in headless mode (-HEADLESS) mode from within a C# (Dotnet) application and send the following commands over the REST API. The error message I get is:
“Exception in HTTP Loop Status: OK
Exception in HTTP Exception: Object reference not set to an instance of an object.”
The functionality still seems to work ok but I curious to learn what causes the exception.
If I run the app from the C# application using “QA40x.exe -C” (for console) instead of "“QA40x.exe -HEADLESS” then it works fine with none of the HTTP exception messages.
Can anybody possibly shed any light on the cause of the HTTP exception messages when using headless mode?
Jesse
