I was unable get the “save as bitmap” function to work, or the “export frequency series data” function to work. Are those functions available, or could I be doing something wrong…? THanks!
Hi @VAR can you please try release 0.994 and see if that fixes it for you? Prior to that, the export/import was broken.
Thanks- I will try it later today or tomorrow and report back if there is still a problem.
HI @VAR, I see file save bitmap isn’t working. It will go into release next week. In the mean time, you can grab bitmap onto the clipboard via edit->copy bitmap to clipboard
