QA403 ADC overflow
Running V1.220 on Win11 Pro. Recently I have seen a ADC overflow error and I can see the bad data in the Freq and ime display. The video shows the problem ADC over flow Frequency domain. I used 64k FFT with no averages, running at 192k sample rate. Here are 2 videos: ADC overflow - Frequency Domain and ADC overflow Time Domain
I did notice this problem in the past, but it was very infrequent.
Hi @tspacker, does this happen at 48k? When this error happens, the hardware is telling the application “I had audio packets, and you didn’t request them before more packets came in and I had to drop the packets that were queued”
I have not seen it happen at 48k or 96k.So only at 192 as far as I can tell.
Hi @tspacker, you might see if your bios has an update available. See thread below.
