Hi @mhuth1776,
I think there are two issues here that hopefully aren’t overlapping. The link below goes through some things that need to be done when looking at THD and low frequencies. Some have been fixed, but it’s a good overview of the math and how low frequencies need a bit more attention.
Second, can you please try this:
- Set up for left-channel loopback for L+, and short L- input
- Set File->New Settings
- Go to Gen1 and disable round to eliminate leakage
- Set 0 dBV full scale input
- Select the AmpThdVersusFrequency Automated Test and setup as follows:
This will run 1000 cycles. While running, use your machine as you normally would–videos, downloads, etc
Here’s the plot I get at 48K:
And then I changed the sample rate to 192 and press F3 to run the test again:
Can you run this on your machine and share what you get?
