I thought I’d start my own thread rather than clutter up the very interesting Stereo Phono Input testing thread that’s been going on, with a tangential question. Hopefully the answer is simple but I’m not sure what it is I’m seeing…
Background here is that I’ve been testing some vintage phono stages in Marantz receivers and integrated amps, both restored and unrestored. I’ve made a lot of progress and really gotten a much better understanding of what to do/not do and once again how darn versatile the QA403 is. And many thanks to @VAR and @restorer-john, by the way!
Okay, so one thing I’ve been investigating is a common Marantz phono stage (same board was used in a number of different models) that can be made to “motorboat” - exhibit a loud low frequency oscillation - if certain modifications are made and certain conditions presented to it. Namely, the mod is replacing certain vintage transistors that tend to become noisy with modern low noise substitutes. The performance is fine but there are stability issues that are seemingly related to differences in Cob of the transistors - but that’s not really the point here…
Anyway, my question relates to an interaction I am finding in some cases between the phono stage and the Input of the QA403. I’m weak on this theoretical stuff so any enlightenment would be welcome! My crude assumption is that the input impedance of the QA403 must be changing as I change the “Full Scale Input (dBV)” setting in the software, and if it gets too low it can set off oscillation in the phono stage.
I get that there is a relay involved and a physical resistance is switched in and out when going between the 18 and 24 settings. But what is happening between the other settings? And specifically, can anyone tell me what is the impedance seen by the phono stage output when the QA403 input is switched between 24, 18, 12, 6 and 0? And my apologies if I missed where this is spelled out in the FAQ’s or Wiki - I’d gladly go read that, too.
The one thing I found is a statement by @matt in another thread Input Transformer Measurement - #6 by matt that reads “the input impedance appears as follows: The BNC input goes to a 4.7uF cap in series with a 470 ohm, followed by a shunt of 100k ohms. Overall, we consider it a 100k series input.”
But clearly it’s not constant and must be changing as I switch between Full Scale Input settings… since I am able to trigger oscillations in the phono stage output if I go too low… yes? Maybe?
If I understand what the QA403 input is doing, then I can better solve the problem caused by the phono stage modifications.
Thanks in advance! -Steve
