Is there a way to change this? I would very much be interested in reading THD measurements at say 20kHz. I have my sample rate changed to 192kHz so I should be able to measure 3 harmonics of 20kHz at least. I even changed the x-axis scale and stuff. Am I doing something wrong?
Did you try and right click the THD button and set the range there?
          Ah, yep, that seemed to do the trick. Thanks!
