Does it exist or do we have to composite results from other provided (more “atomic”) cmds?
Hi @mcq, it’s there but the name is a bit confusing to avoid the ‘+’ in the REST command getting escaped into something hard to read in the logs.
With the QA40x app open, go to your browser and open localhost:9402 and you’ll get a list of the REST commands. And then control-F on thd+n and you should be taken to the appropriate REST command. In this case, you can see it’s simply called ThdnDb. You can also use ThdnPct if you prefer.
Thank you, Matt! I appreciate your help…
