There are many adjustments on an R2R recorder, but the most important are head azimuth, playback response, and record calibration.
For head azimuth, simply follow the service manual. Personally, I’ve never had to adjust it.
For playback equalization, you normally need a dedicated calibration tape. These tapes are expensive and should match both the recorder and the tape formulation (LPR35, LPR90, etc.). For personal use, this is often not worth the cost. I use two Revox B77s, and tapes recorded on one play identically on the other, so I don’t adjust playback EQ.
The greatest improvement usually comes from record calibration, which includes:
Bias adjustment
Record level
Record EQ
Ideally, you need only an audio generator and a true RMS voltmeter (reading in dBu is a plus).
The standard bias procedure is to record a 10 kHz, -20 dBu signal, monitor the playback output, find the maximum level, then continue increasing the bias until the level drops by about 5 dB (depending on tape type and speed).
Record level is adjusted with a 1 kHz, 0.775 V signal.
Finally, adjust the record EQ with a 12 kHz, -20 dBu signal. Since increasing the bias reduces the high-frequency response, the EQ trimmer compensates for this.
It may sound complicated, but the real objective is simply to obtain the flattest possible frequency response.
This is where the QA403 becomes extremely useful.
Run a Frequency Response measurement (20 Hz–20 kHz swept bursts) and watch both channels in real time while adjusting the bias and record EQ trimmers for the best response.
The service manual remains the reference for the adjustment sequence and target values, while the QA403 makes the optimization much faster and easier.
I honestly think the procedures described in the service manual were designed around the test equipment that was commonly available at the time: an audio generator, a true RMS voltmeter, and perhaps an oscilloscope. High-performance audio analyzers were extremely expensive and generally found only in professional laboratories.
With a modern analyzer such as the QA403, you can directly observe the recorder’s frequency response in real time and optimize the adjustments much more quickly. The service manual still provides the correct sequence and target values, but today’s measurement tools make the process far more straightforward.
