Testing amps upto 300W into 8ohms
Hi everyone,
I am designing a tapped dummy load for high-power amplifier testing with my QA403.
My immediate goal is to test a 200W into 8 ohms amplifier (40Vrms). Because this hits the absolute maximum input limit of the QA403, I want to build an attenuation network with enough headroom to eventually test amplifiers up to 300W into 8 ohms (48.99Vrms).
Based on the QA “Power Amp Basics” blog post, I plan to split an 8-ohm total load into a two-resistor voltage divider to target an attenuated voltage of 35Vrms at the analyzer input.
Proposed circuit values:
  • R1 (Top resistor): 2.28 Ohms (Dissipating ~86W at 300W total power)
  • R2 (Bottom/Sense resistor): 5.72 Ohms (Dissipating ~214W at 300W total power)
  • Connection: Differential tapping across R2 to avoid ground loops.
This should yield a total attenuation of -2.92 dB, dropping the 48.99Vrms down to a safe 35Vrms for the analyzer. I plan to use parallel arrays of non-inductive power resistors on a heavy heatsink to handle the thermal load.
Are my calculations correct for this target? Is there a more optimal resistor ratio or alternative approach you would recommend for this power level?
Thanks!
I would calculate more external attenuation like 18 or 24dB for safety.
I’ll send you later my schematic which works well at 2 and 4 ohm 1000W and 8 ohm 500W.
And there are some threads here about this theme.
Here it is:
Thanks! This is awesome!
I use huge load resistors
500W 8 ohms → 500W 8 ohms
in parallel
500W 8 ohms → 1000W 4 ohms
in parallel
500W 4 ohms → 1000W 2 ohms
The oscilloscope output is only for controlling the signal curve, not for voltage measurements.
With this setup I get this result without signal and DUT:
Edit:
