Testing X-Plot Response
Tested it, but the Generator selection didn’t work, my ears brocke away even if i select 0.05 V ouput Voltage it goes @ full Power!!! i need to stop that.
Also if i hit the 0.05 selection it shows me 5 V
You should start with understanding the maximum input specification for the DUT
What you talking about it was an Error in Software, MarkZ has alredy repaired it and the Voltage settings working right now!!! if i hit @ 0.05 V and it switched to 5V thats not funny dude!!!
My reply was not intended to be funny or sarcastic. It is simply a good idea to check the working parameters of the input. If this is a LINE-IN signal the operating parameters are DUI specific. It is very possible that if you have run 5v into the source you may have created some additional damage.
@YamahaCA .. I agree but if you follow the actual thread where this problem was being dealt with, it’s not this thread. There WAS an issue with QA40XPlot that was causing Frunse’s over voltage problem which has been fixed by the developer Mark Z. It is all in the QA40xPlot thread. I think Frunse posted here in error
Ok no damage aplied i used the Amp already with this Speaker and the Measurments looking like before, so no damage there, i stopped the Signal as fast i realized it is to loud.
yes not sure how it comes to this Thread clickt on wrong Buttons i guess LOL
@Frunse This entire thread should be posted as comments in the unofficial (but awesome) QA40xPlot thread.
Yes i tried to answer MarkZ and than it was in the new Thread here, than i did the same Post @ MarkZ thread LOL
How to delete this???
