Automated test AMP THD versus frequency
With it’s default setting I get this error.
What’s happening here, what should I do?
There could be several things happening. A very common problem is the input overloaded while running the test. it’s harmless, but when overloaded, the data can’t be relied upon. In the error cited, you’ll see Illegal Values Passed to FindPeakBin
That can come from no data (due to overload) or you have specified start freq is > stop freq. Since it’s not possible for the latter condition to occur at this stage, I’d guess input overload was the culprit. Remember to use sweeps, you first want to ensure you can manually make the measurements. That is, if you are wanting to look at THD from -50 to 0 dBV in a sweep, first make sure the measurement can be made manually at -50 and also 0 dBV.
Can you please post the setup options you used for the test?
I didn’t specify anything, I try to run it with the default settings. I will check again!
