Is it possible to expand the frequency range of signal spectrum displayed in the main window beyond 20 kHz (at sample rate 192 kHz)? How?
Hi @Peter . Right-clicking on the XLIN or XLOG button opens a window where you can set the minimum and maximum value of the displayed frequency.
Thank you very much for the answer. I must add, however, that this was the first thing I tried before writing the post. Unfortunately, the option did not work. After restarting the system, everything was fine. Best regards
