Hello everyone,
I’m investigating isolated line-level output and input at the moment. It seems possible for a decent frequency range, provided the levels are quite low, around 0.3Vrms (-10dBV) level. Here are the specs. I am aiming at.
Line Out:
- Source impedance around 100 to 600 Ohms
- To load impedance 10k Ohms or more
- Sends 2Vrms level but could be as low as 0.3Vrms
Line In:
- Input impedance 10k or more
- From source impedance around 100 to 600 Ohms
- Accepts 2Vrms level but could be as low as 0.3Vrms
I am curious if anyone has suggestions for a decent isolation transformer I could measure?
Here is the frequency response of a few transformers.
The 100-001 is something like these cheap transformers built around EI-14 cores:
and the other options are larger and more expensive.
Low-frequency response and THD is always an issue with such small devices for two reasons:
- large inductance needed to avoid low-frequency roll off and this is just plain hard in a small form factor, and,
- voltage-time (V-t) product of the signal is larger at lower frequencies, meaning that the core can more easily saturate.
The THD shows an interesting behaviour. For very low input levels (less than -16dB) THD is around 1% and this improves as the signal level increases. But below 100Hz pretty much any signal level cases greater than 1% THD.
I suppose I am abusing the transformer a bit. It is designed for 600 Ohm : 600 Ohm and I am using it terminated with 10k Ohms. Although this might improve the frequency response because the current in the secondary will be less. Although it might be a bit more complicated than that ![]()
