I’ve had the QA401 for a few years now and have been enjoying it. However, there are still some things that I would like to recommend for the UI of the software.
I wish that there were some more options for the graphs like solid lines instead of dotted. The dotted lines are kinda hard to make out sometimes so having a solid option with some different widths and subdivisions would be welcomed.
Also, as someone that changes from balanced to unbalanced audio tests frequently I thought that having a 6dB output compensation button would be handy. Having to go into the dB axis menu and manually entering the ext gain gets a little annoying. Just a BAL/UNBAL button with an annunciator (like the 20dB Atten that pops up on the graph) would do. Also, I noted that running a test plugin resets the external gain comp in the main window, and it’s easy to forget to add the compensation back. It’s caught me off guard a few times so far.
It has been a while since a 401 update, so I’m hoping one is in the works that can possibly add these small things - or if the QA40x software could include the 401, so that 401 owners can continue to receive updates along with 402 and 403 owners.
Thanks!
