QA451B issue with external loads
Ahh, yes, OK I get it now. Noted, thanks.
I can use the center point between the resistors to get 6 dB of attenuation if I need to.
Yes, just be mindful of the bal/unbal limitations you might run into. The issue should be lessened becuase of the low value you have on the lower leg. But run it in SPICE if you plan to use unbalanced.
The amp dynamic plots are super informative and interesting. Is the 10mS increase in gain in the last plot the supply rail ramping up and disturbing the loop??? Or, asked another way, what test would stress a class H amp the most?
