I’m not sure how much detail to put here. I’m adding the graphs at the end, to keep this more manageable. If something looks completely crazy, I’d appreciate feedback, but I don’t expect anybody to go in detail through all this.
First I spent some time using the AD2 (100 MHz USB scope), with no transformer in the signal path:
- at low signal levels the computed difference between the channels taken from the ends of the 8 Ohm load looks truly atrocious. This is with injecting a 1kHz signal from the AD2 generator into the amplifier.
- With a faster time base, I see 10 MHz base frequency pulses, with bursts/chirps/pulse trains repeating either every 16 or 32 pulses, which I assume correspond to the two PWM frequencies of 330 and 660 kHz. The signals I see do not look like rectangular PWM pulses to me.
Switching back to the QA403, and trying to approximate Matt’s setup for the MA12070 (1.46 Hz FFT bin width, 20Hz to 20 kHz measurement window, -60 dBV input signal, 20 dB gain, 5x averaging, A weighting), but using the small audio transformer and no other filters in the loop except what might be built into the A30, I get 100 microVolt noise (-80dBV), not 65 microVolt. I can not get completely rid of the line frequency peaks, despite protective earth grounding the QA403 (via the bottom left BNC shield), the A30 (via the subwoofer out RCA shield) and the shields of the probe cables from the 8 Ohm load to the transformer. Transformer and QA403 orientation (in the local field) do not seem to play a role, but I can induce a few dB of damping at 60 Hz by touching the BNC shields.
Frequency response (gain) looks reasonably flat, when referenced to the transformer.
I then did some THD measurements, which at lower frequencies (<1kHz) are limited by the transformer distortion. I can get below -60dB above 1 kHz for amp input and output (gain = 1) levels between 0.5V and 2V, so maybe this is not so bad.
In light of all this I also think the higher bandwidth harmonics data from yesterday are ok as well, but I’m questioning whether looking at harmonics in the 10kHz to 50 kHz range is really the best way to assess/characterize the audio distortion of this amplifier.
Therefore I did some intermodulation tests, and some of those, at higher gains and power levels, are not looking so bad either. I’m thinking those might turn out to be most useful to compare different amplifiers.
Signals on both sides of the 8 Ohm load, while injecting 1 kHz into the amplifier:
Amp output into 8 Ohm, seen through the transformer, at 1V input:
The AD2 FFT does not look anything like I expected; there is a narrow peak around 250 kHz though:
Back to the QA403, looking at noise with no input into the transformer:
Trying to reproduce Matt’s settings, now with signal (details in text above):
Interestingly, there is a peak at 17.5 kHz, but not at 9 kHz like in Matt’s data.
Making the connection to my higher sampling frequency measurements from yesterday; the noise number is comparable/same when restricting the bandwidth:
amp frequency response (blue) vs transformer response (red):
Plotted as ratio:
THD seems high, but improves at higher signal levels and higher gain. The next three plots are still at gain of 1, red is the transformer reference channel:
THD vs power:
Abandoning the direct reference comparison, intermodulation seems not so bad at maximum gain:
19kHz & 20 kHz 1:1 at 1W:
250 Hz and 8 kHz 4:1 at 5W:
The amplifier is not much worse than the transformer, but obviously at different voltage levels.
