Averaging using 1.183
Using my QA402 and firmware1.183. I’m trying to use averaging but I only see it go through average 0 and 1 even when set at 4 or 10, Is this intended or a issue. I would think we could average all we wanted on about any test.
Thanks for any feedback
Jerry G
Hi @ggorman, it should work.
Can you try this: Disconnect all the cables, select File->New Settings. And then press space bar to start running. And then adjust the AVG with the up button until you get to 10. It should quickly run up to 10/10 average.
When you change most settings, it will reset the averaging count to 0. For example, if you enable A weighting, the average count will restart.
