Would it be possible to add RMS volts and also Watts / load impedance as options to the RMS measurement?
Hi @Tonywood, I think these are both there:
You specify your load impedance for the watts measurement in the DBV context menu.
Thanks Matt, I’m a moron! ![]()
Hi @Tonywood, it’s hard to find the tests if you don’t know what to look for. But! You can search on “watts” (no quotes) or dBV or dBr if you need your memory jogged. The search filter is at the top off the “Add Measurement” dialog.
