I just received my QA401 this week, and so far I am very pleased with the unit and software.
My questions is, is there any way to change the scale from dBV to dBm for the test plugins?
I know you can change it in the side control panel, but that doesn’t seem to change the it for the test plugins - just the active display and general user interface. I work more in dBm than dBV, and would like the test plugin graph scales to be in dBm. I plan on mostly using the AMP Frequency Response test plugin.
Hi @M2Circuits, there’s no way currently to change the units to dBm. But you could fiddle with offsets and do it. Assume we’re talking about a 600 ohm system (recompute for whatever characteristic impedance you wish):
Note to go from 0 dBV into 600 ohms to dBm requires you to add 2.21 dB. And then, 6 dB more voltage yields 6 dB more power. And 12 dB more voltage yields 12 dB more power. So, if I add an external input gain of -2.21 dB in the plugin setup:
Then the resulting graph is as follows. Note that we output 0 dBV, but it’s measured as 2.21 dBV because of the offset we specified. So, that gives us the correct value.
