Q403 grounding point
Hi all..
I’ve finally built my rack box to house my q403. It brings all the connectors out to the front via xlr,b&c and even the usb and a ground.
My question is where is best to attach a ground on the 403 so I can strap the gnd for different configurations.
Thanks for any advice..
Cheers
Skip.
Would be nice to see some pics of your system! Your grounding question is a little tricky. The QA403 box is electrically connected to the USB ground. I would try to keep this part floating with respect to your audio ground. It would be easier to find a good solution if you reveal more about your rack, pics would be very helpful…
Christian
Hi there.
Here are a few pictures of my design
I have the grounds of the xlrs connected.
The rear ground is isolated and the usb is as well..
Any advice on where on the 403 would be good to connect the ground would be great..
Cheers
I would be wary putting the unit in a closed case as the QA403 gets pretty warm with a about 5W of constant heat to get rid of. The vent slots are on the sides.
I can add vent slots on the sides and bottom
Any advice on ground points?
Thanks for the help..
Sorry I can’t help with the ground point but I wanted to ask why do you have 4 xlr inputs and 4 xlr outputs? Are they unbalanced or just splitters?
Hi @skipburrows. In the past, I ran some tests with my QA403 to find the grounding point that minimizes the ambient noise introduced. I found that using the bottom left screw on the front panel of the QA403 as the grounding point gave me the best results (after optimizing the grounding paths, of course!). Here is an example of what I get when I connect or disconnect the grounding point. The test was performed by measuring the noise output from an amplifier card. I don’t know if this will be useful to you.
Hey there.
No just “y” connections.
Useful for connecting things extra like headphone amplifiers and even scope to the in our out with the device under test.. better to have it and not need it than need it and not have it!!
Hi.
I’m skeptical about such an extensive measurement system. Better results are achieved through symmetry, shortening the cables, disconnecting the laptop from the mains during the measurement, etc.
Below is my system. Please note the short and thick measurement cables and terminations (probes).
Here are the son's details:
Here’s the ground point. It actually improves the background spacing.
Here are the background levels achieved:
Grzegorz
I ground the DUT by an extra ground wire from a QA403 BNC connector to the PC’s chassis (a HP ProDesk 400 PC). This improves noise suppression, spurious and 50 Hz. residuals a lot.
Note: Grounding the QA403 chassis did little or nothing at all in this respect.
Hi, Grzegorz.
My question is how did you get the extremely low noise floor with measurement settings in the program? My QA403 gives a best of - 120 dB with 512 k FFT size and 10x average. All inputs shorted with 50 Ohm, no cables at all. Or do I have a QA403 which has excess noise level?
Update: My measurement used the internal attenuator. Switched to 0 attenuation I got the -150 dB. Sorry for my question.
Sven
Hi Sven.
I was just about to reply.
Exactly as you pointed out: with 42dB attenuators, you'll get about -120dBV, and with a 0dB attenuator, you can even get down to -160dB.
Note my short cables and probes. Everything is symmetrical. You could try a bit with ground shielding, etc.
And the final measurements are done using the laptop's battery, and I sometimes disconnect from the mains to power the DUT with the battery as well.
Grzegorz
Gregorz
The attenuator causes the input resistance to be much higher than the 50ohm short would imply. When the setting is 0…18dB the 50ohm short creates an effective 606 ohm resistance on the analyzer input . So the -150dB noise level is from this 606 Ohm resistor. In the 24…42dB attenuation setting the resistance raises 5860 Ohm and that’s where the -120dB noise levels are coming from. If you need lower noise you need to create your own attenuator and use the 0…18dB setting. Had the same learning as you a while ago .
Maciej
Good inside view. For low impedance sources a custom attenuator with low output resistance is a good choice for reducing noise.
I use a QA403 connected to a laptop via USB and at the left input a power resistor with a divider, 2 and 4 ohm 1000W, 8 ohm 500W.
With all inputs terminated 50 ohm I get this:
Thats very ok.
With open inputs on the left:
Quite normal.
Now I connect my load resistor with built in 40dB symm attenuator, symmetrical connection, chassis of the load is connected to AC ground without ! connection to QA403 ground or housing:
And bump, there is hum!
Another problem is solved, first I saw this FFT with an osci connected by BNC and an attenuator to the circuit
with power plug connected to the osci
Power plug disconnected
Thats a lot better, but a 50Hz peak resists.
All electronic devices in the near are off, laptop on battery, all lamps in the room off.
Grounding BNC or housing of the QA403 to AC ground does increase (BNC → ground loop) or does nothing (housing) to the peak.
Measuring high power amps shows a lot of 50Hz induced intermodulation distortion, which I’ll avoid.
Any suggestions or hints?
Thanks
Christian
thats my new schematic of the attenuator in front of my QA403:
It’s the circuit which Matt recommended.
Paintig this, I noticed that at my current circuit I put the connections to the osci after (!) the 5k11 resistors - completely stupid…
I’ll show the results with the corrected circuit later.
As long as your oscilloscope is NOT grounded.
Right, its not grounded at all, but may be it injects noise or hum in this position.
