QA403 Firmware Update Failed
Hello,
I don’t think my QA403 has managed the firmware update. I wanted to update to version 1.201.
The QA403 is still recognized as two devices in the device manager:
HID compatible manufacturer defined device and USB input device
with VID 1FC9 - PID 0022
Is there any way I can bring it back to life?
I have seen a thread mentioning a workaround with internal bypassing of a test point.
Kind regards,
Magnus.
[quote=“Magnus, post:1, topic:1419”]The QA403 is still recognized as two devices in the device manager:
[/quote]
Hi @Magnus, based on the VID:PID, you are in bootloader mode.
Plug in the hardware, make sure the QA40x app has focus, and type the letters “qa40x” (no quotes). Also, make sure you use the keyboard numbers above the QWERTY letters and not the numpad numbers.
Once you enter that, you should hear a beep and see a new menu called “Debug” in the QA40x menus. Select "Load default secure image (must be in HID mode):
This will load the appropriate image into the QA40x hardware.
Please let me know if this works for you! Thanks, Matt
you were absolutely right, the QA403 was in bootloader mode.
Now it works again as before.
Thank you very much.
