Planning to run the following setup:
QA401 -> transducer amp -> ref speaker -> “DUT” which is a microphone
-> XLR+phantom -> mic-pre -> QA401
The DUT also has USB-audio class output via an internal ADC that needs to be tested (not part of the XLR signal chain)
Question:
Can we somehow pipe the captured chirp to the same analysis process?
i.e. we will capture the usb-audio to a local .wav file then hopefully be able to pipe it to the QA software!
Hi @audio-dav, Your first setup should work fine where you are using the QA401 DAC to drive a speaker and then capture that back into the QA401. The first link below is similar problem, but comparing a mic to a reference mic. But in your case, you can readily capture the chirp and compare to a mask.
For your question about loading a captured chirp into the QA401 software…that’s not currently possible but it’s a very reasonable feature request for the future (but not near term, unfortunately).
Any alternatives to solve the USB-audio capture?
I’d rather not do [mic -> adc -> usb audio device] -> usb cable to computer -> USB-soundcard/DAC -> output it back to the QA401.
Not at this point. Just to make sure I understand: Is what you are looking for the ability to load a WAV file and then have analysis performed on that WAV file both in the app and also via Tractor?
Hi @audio-dav, currently there’s the ability to File->Import a time series. This will let you pull in a time-series you’ve previously exported. If you had an external program that was writing the WAV, you could also have it write out a time series and then File->Import that.
But I think what we need to do here is:
Add the ability to import a WAV from the file menu
Add the ability to import a WAV or time series programmatically
Add a test in Tractor that will force a WAV file to be loaded in QAAnalyzer.exe
I don’t have an idea when the above will be done, but they are on the list.
# TIME SERIES
# 5/20/2020 9:57 AM
# Units: Volts
# Sample Rate: 48000
# Pre Buffer Size: 2048
# Data Points: 16384
# Atten Enabled: False
# Time, Output Left Data, output Right Data, Input Left Data, Input Right Data
0.042666667, -0.113730041, -0.113730041,-0.102785794, 0.000000925
0.042687500, -0.127531189, -0.127531189,-0.117832134, 0.000018351
0.042708333, -0.139162639, -0.139162639,-0.130867125, 0.000026370
0.042729167, -0.148425763, -0.148425763,-0.141663462, -0.000019739
No, that’s not in the plans currently and probably won’t be added unless a really good use-case presents. The WAV import makes sense so that you can pull a wav from a remote server (an http address should work for the file name). This should permit testing mic sensitivity/frequency response on a internet connected device.
