Acoustics Measurement Features
Hi, I’m an AV consultant by trade and I’m considering getting a set of these machines for measurements in field. But recently I’m also taking an acoustics course that requires us to do some projects and measurement. I’m trying out the demo software, may I ask if there’s any acoustics-related or sound level meter features in the current (or feature :p) software packages? such as,
  • User defined unit (SPL, dBSPL, or just dB)
  • microphone sensitivity calibration (94 & 114 dB)
  • RTA, FR in 1/3 band
  • Integration time for averaging (e.g. 15 s)
  • Reference curve overlay (X-curve, NC, NR, …, user defined)
  • Seperate A/C/Z-weighting on plot and the final dB reading
  • A note section for text remarks in field.
Thanks!
Hi AndyM,
Take a look at the plot below. What this setup shows is an Earthworks M23R Reference Mic connected to a QA472 Mic Pre with 0 dB of gain and phantom power enabled. That then goes into the QA403. A mic calibrator is connected to the mic. The calibrator has a 94 dB and 114 dB setting. This will show how at least some of the things on your list can be achieved.
The M23R has super tight calibration (+/- 0.5 dB across the band) and a nominal sensitivity of -28.9 dBV/Pa. We can tell the QA40x software the absolute sensitivity of a mic in the dBr context menu (right click on dBR in AXIS control block). Note below we have the -28.9 dBV/Pa sensitivity, and 1 Pa is 94 dB, and thus -28.9 - 94 = -122.9. That is telling the software that when you measure -28.9 dBV, that should display as 94 dB.
Note the gain accuracy on the QA472 is very tight, typically around +/- 0.05 dB It uses an INA849, which is laser trimmed. TI has lots of data on the just how tight that part is. Its like no other mic-pre out there. And the QA403 should get you better than 0.05 dB too. Class 1 is +/- 0.7 dB.
In the plot above, you can see a green reference plot for the 114 dB setting on the calibrator. The live data (blue) is showing for the 94 dBSPL.
The plot below shows 1/3 band response.
There isn’t way to set an integration time and there isn’t a way to measure gapless periods of audio. But, an ASIO driver is available, and so, if there’s software you prefer you could use that. But then you are back to having to calibrate.
There is some other software that has been in the works for doing things like measuring gunshots on a shooting range and live sound/concerts for safety purposes. This will let you continuously log things like A-weighted Leq readings. For example, in the plot below you can see the same left channel as configured above. But this time all the time-averaged metrics you might want are kept and computed. So, you can see where I have clapped near the M23R and hit a peak of 140 dBSPL (red trace is instantaneous peak without any weighting), and then I connected the mic calibrator. Once the calibrator is connected, you’ll see the red trace immediately snap to 94.2 dB SPL and the pink trace (A-weighted Leq over 1 minute) slowly rise to that value over one minute.
This software isn’t ready and I don’t know when/if it will be ready. But it’s a proof of concept of what is possible. And of course, if you can write python or C#, you get the same access to the tightly calibrated audio stream and can do something custom if that makes sense.
@AndyM I’ve recently been using the 1/3 octave band feature. However, it’s important to realize, the 1/3 octave binning in general is a holdover from analog audio analyzers that used discrete filters. This device is digital, which means it has all bands of equal width! (higher resolution in the higher bands). If you use the QA403’s built-in white-noise generator, the 1/3 octave plot will have a downward-trending linear slope bias. Thus you may need a stand-alone pink-noise generator.
I understand decades of course material has utilized the 1/3 octave analyzer with pink-noise generator, however I would suggest experimenting with switching to the white-noise on the standard FFT plot for improved measurement analysis.
Thank you Matt for your very detailed explanation! I’m looking forward to your new batch of stock, but please do let us know if there’s a new QA404 anytime soon.
I also looked at REW, but it seems the QA will give a more coherent workflow, more efficient and less things to worry about. But hey, I could still use REW on QA, so nothing to lose.
Thank you for the insights! That’s really worth some considerations. I hope the user sig. gen / ARB can be made more accessible.
Btw @matt, mind I ask the when will the QA403 have stock a again?
Hi @AndyM, they are back in stock as of this week:
I was just checking the signal gen again, tbh I think pink noise is more common in non-anechoic field, white noise is usually used in anechoic field, outdoor environment, and electronics.
SMPTE has standardised a pink noise with python code available. But of course white+filter is also a choice. Either way iope it can be included as a standard signal too, along with square wave for impulse response etc.
I think white noise is appropriate for microphones. Pink noise is commonly used for loudspeaker measurements because it doesn’t risk blowing tweeters or deafening people so much if at high volume - it also matches a music spectrum much better.
Thank you very much for the tutorials @Matt, started to get the hang of it now.
I do have a few silly questions tho. Unlike typical sound level meter, I see the plot falls through 0 dB even without any weighting, is there any reason why?
Secondly, is there a way to adjust the dB range in the 1/3 band spectral visualiser?
Many thanks.
