This has cropped up several times and sometimes “cured” itself mysteriously - when running the AMP Frequency Response automated test, the test just continuously loops and doesn’t stop after one cycle to show the resulting plot. I’ve tried to nail down something to stop this behavior to no avail. Of course this behavior never yields a useful plot.
Could this be a bug somewhere in the software? Reinstalling the software and creating another test template doesn’t cure this behavior. I always run the latest version of the software.
The settings are typical 10Hz - 95kHz, 96kHz sampling, -40dB level. I’ve found that this happens under different settings too. The problem is that there doesn’t seem to be any pattern. I’ve completely re-installed the application and that doesn’t cure the problem. I’ve owned almost half a dozen QA 403s and I’ve had this problem crop up randomly with the other ones too. Most of the time the frequency response (non-chirp) works great, but when it gets into exhibiting this problem, nothing I have been able to do will clear it up. The measurement just keeps looping and never stops, over and over. Frustrating since I use this function quite a lot.
A measurement stop frequency of 95kHz has always worked and seems unrelated to the endless loop problem. The sampling rate is 192kHz in any rate - if I said something different, then I misspoke. Inputting this stop frequency is allowed by the software in any case - if it’s illegal, then the software should be changed to make this impossible, just like using 100kHz is not allowed. In any event, I do not see this is as the problem in this instance. You may be correct about the Nyquist frequency, but it seems irrelevant to this particular problem, which is that the automated test does not stop after one cycle.
