How to control four QA403 units using a USB hub?
Is it possible to connect and control four QA403 units using a USB hub?
Any documents to describe the setup?
Thanks.
Hi @Thomas, no it’s not currently possible. But if you notice in Help→About, there is a serial number that is unique to every device. At some point in the future, that will be used so that you can specify the SN that must be connected on the command line, and you can have 3 or 4 instances of the app opened if you wanted to. But that’s not for 2025 for sure.
