Hi. The latest release and pre-release versions of the QA401 GUI both run into issues on a Microsoft Surface Pro 6. The screen specs are:
Screen: 12.3”
Resolution: 2736 x 1824 (267 PPI)
Aspect ratio: 3:2
Microsoft default is to run 200% screen scaling for text legibility on the small screen. The QA401 GUI launches properly scaled but resets to the native screen resolution with 100% scaling when a random control button is clicked. Menu text become ~1mm high. It doesn’t appear confined to a particular button and occurs erratically. Sometimes the GUI works fine for a bit then re-scales on the next click.
When this happens the GUI changes from full to partial screen. Clicking the maximize button makes the GUI window smaller. Clicking a second time maximizes the window without scaling. The Surface OS is fully updated. Using a display setting of 1920x1200 with 100% scaling may work properly, it hasn’t been used enough to be certain.
Apologies for the amount of info here. Any suggestions on locking the GUI resolution? Thanks.
